1 - 20 of 23 Posts
I've had this odd clunking sound for a while now. I have had UCA's and LCA's on the both sides replaced. The right side was Ford, the left was Moog. I think the clunk is coming from the driver's side, but I'm not 100%. The recording was taken on my phone (sorry) while it was laying in the floorboard under my feet. The recording is a little muffled, so the real sound is a little more like a rattle. Any ideas?
http://www.youtube.com/watch?v=frgU5YvNDYc
ehh, sounds like a bunch crap rolling around..
How do you guys determine the Sway bar links without the car actually being driven???
its called an imagination!
:tongue:
I suppose. Unless its just a recording of the noise with a still shot of the car in it.
EDIT: Should have actually read the post from the OP. oh well.
Sounds like a broken rear sway bar link..could be either side...
Rayo...
EIT: Should have actually read the post from the OP. oh well.
Yes, I did ASSUME (I know what it spells) it was just a still he put on the post, but the recording was done with the car moving. Didn't he say he had the phone on the floor recording?
:rolleyes: Read the Edit.
Oh, I see. So again I was supposed to ASSUME that you meant with this comment what the OP meant (he didn't really state he was moving, so you ASSUMED too).
I'm just saying :zdunno: :D
ok are you gonna follow me around the boards? Take your instigating bullsh!t somewhere else gramps
I'm hope you're just messin' around, cause I wasn't trying to offend you in the least. Maybe you should go get you some.....
Giving your track record regarding what I post, Yeah. And at least mine is still working.
GETTING BACK ON TOPIC.............
It definately sounds like a endlink. You just need to determine wether the sound is coming from the front or rear. From the vid it sounds like the rear ones. I replaced both fromt and rear at different times chasing down that clunk. Do yourself a favor though and get a GOOD set of links. I bought Raybestos ones from Rockauto and 3 months/1K miles later they are still good where the others lasted me maybe 1 month before making noise again.
That's an ugly rumor. And those little blue pills I take are for my sinuses! :eek:
To the OP, bad front links I always found to be more of a rattle. Rears were a hard clunk. Either way its still hard to diagnose through a video of sound. Do what I did. By all 4 links as preventive maintenance. They are fairly inexpensive and you'll be happy to know all the links are completely out of question. Good luck.
you know, if you are afraid to spend the money, then just unhook or remove all 4 links, and see if the noise goes away.
Yeah that'll definitely be a good way to find out. Hopefully he wouldn't drive it like that tho. I drove JustinH's vortech bird with no links front or rear and oh man I was getting sea sickness in the turns.
try driving the 73 bird...or my 98 lesabre....ugh, no handling FTW!
My 95 is okay....I only run a rear sway bar...no front. I also run skinnies up front with no pwer on the power rack......
1 - 20 of 23 Posts
