1 - 11 of 11 Posts
ok, when accelerating, if i suddenly let off (around 4000rpm and up) i get this squeel.... 1st gear doing a burnout, but not standing still, rolling forwards
it has also done this on the 2-3 shift (3000-4000rpm range)
and just now on the way home it did a much longer version of the same squeel, but i was just idling (well just a tiny bit of throttle) away from a stop sign
it sounds like the belt, but it only does it when there is a load on the engine...which leads me to believe it may be the tranny
:confused:
anyone experienced this?
Discussion Starter #2
no one?
Yup,
I had the same thing happen to me...It will also do it when the AC is on in park If I would rev the engine...Like The great obucina said, replace that thang!
well the belt is failry new, only a couple months old.....is it just slipping....maybe i should go with a slightly smaller one? what is the length of the stock one
what brand? i had a gates that constantly slipped after just 3 months. Get an OE sized Goodyear.
will do, thanks
Mine made a noise like that when the idler was going out.
It was slipping across the stuck idler.
It was smoking when I finally saw it while it was making noise. That'll get your attention!
ahh, good tip i'll try that first....it's cheaper, lol
wasn't the idler....i'm getting that belt tonite
got that belt, hasn't done it since:thumbsup:
1 - 11 of 11 Posts
