... and would like some leads, suggestions, pointers, etc, including but not limited to parts sources, rechroming shops and similar items related to the body-off-frame restoration that the car is currently in the middle of.
Lots of steel panel replacement going on and while that's happening I'll be doing the running gear and drive train. It's a manual car, so am also interested in any info about the optional manual 3-speed with overdrive transmission - may want to swap in the overdrive while it would be easy & simple to do.
I'd like to find out about the details in doing a high-end restoration, the best we can do but probably not concours quality - it can't be a numbers-matching car as the original motor was swapped out back in 1968 and traded in back then.
Any and all help & comments appreciated.
Regards,
Larry W7LES in Cheyenne
Larry,
Suggest you hook up with VTCI (Vintage Thunderbird Club International) for info on your classic Bird.
