1 - 1 of 1 Posts
Looked around, but didn't see anyone that went with an offset this low. Will a 17x8 with a 20mm offset fit on my 97 cougar? the bolt pattern and is correct and hub size would be fine. I'm guessing it has a low enough offset to be far away from the inside spindle hitting the rim, and I'm guessing the width isn't too wide to worry about it going past the fender. BUT, thought I would double check.
1 - 1 of 1 Posts
