Two questions. Still contemplating what to do with my T-bird...
1. Will the 3.8 accessories such as the AC compressor and power streering pump bolt up on a 5.0 block without having to modify the length or location of AC and power steering lines?
2. Supposing emissions testing was not a problem, and I didn't care about service engine soon lights, could an older carbuerated engine be used in a 95 Tbird with the 4R70W transmission? Would the EEC still function and control the trans without the engine connected to it?
PS --> I know the "right" answer is to just buy a V8 car. But there's no fun in that :)
Pedal Faster
Well, I'm not sure, but I think the answer to both of those is no.
The second one I'm a little more sure about because I think the EEC requires at least a TPS input to send the correct signals to the transmission. In the case of a 4R70W, it might be easier to get a late-model Mustang 5.0 MPFI setup and piggy-back your ECM on the Mustang inputs to control the trans.
I suspect the answer to both is no also, but I'm not sure either. I figured someone has probably tried it somewhere.
With respect to the 4R70W trans, I suspect the EEC would need a tach signal from the engine too to control torque converter lockup? I have no clue, though honestly....
Thanks for your input Josh.
