Just had an oil and filter change on my '96 XR7 3.8 V6.
The Mechanic filled the crankcase with 5W-20 oil, and an Autocraft oil filter. Did he use the correct grade of oil? Is The filter of good quality?
For the oil - what does the owner's manual say? My copy of the service manual specifies 5W30 for normal usage; 10W30 if the coldest will stay above 0F. So I'd swap to 5W30 next oil change. The brand is somewhat important also - for that, I'd scan through BobIsTheOilGuy.COM and see what he recommends that's local to you (I have been using Motorcraft 10W40 in my 1991, which is a recommended weight for it ... but am now using Valvoline High Mileage 10W40 due to the increasing price and difficulty getting Motorcraft SynthBlend 10W40 around here.)
Autocraft - I stick with Motorcraft myself, although I've just swapped to a FL-300 from the FL1A that my 1991 5.0HO specifies (the FL-300 is 1" shorter, but also fits the Dakota, so since I get a quantity discount ... )
For what it's worth, I use 10W30 for my 4.6 V8.
Filter? Does the 3.8 V6 need a filter with an anti-drainback valve?
My 4.6 needs an anti-drainback valve, to prevent "dry start" knock. My shop uses "Brand-X" filters that cause a knock on start up. You would think they should know better. They probably do, but they save many thousands of $$$ by using aftermarket parts.
I do my own oil changes and use a Motorcraft FL820S filter. I think the equivalent for your 3.6 is the FL400S(?)
A Motorcraft oil filter costs about $2-3 more than aftermarket filters. Why would I try to save $2-3??
It may not NEED one, but it sure should HAVE one.
It's got cam bearings, they're just in the block, not above the head.
If that's the case, you're overpaying. Check out Amazon. :wink2:
Yes, Amazon has good prices, and free shipping for "prime" members.
I said about $2-3 more for a Motorcraft filter, but that was just an estimate. Any time a price is mentioned, someone will say they got a better deal. :)
filter
:wavey:
$3 is nothing. Price an engine.
I run RACING filters. Motorcraft racing is good.
I also run 20w50. BUT that is for racing!:headbang:
5w30 should be correct.
what's the milage?
:zbench:
