1 - 20 of 24 Posts
Im looking for as much advice as possible for an oil filter relocation kit. I was looking at the kits on summits site as a start but im not wure where i could mount the new filter. Any help or pics would really help alot. Thanks, John
awww comon. The filter aint that hard to get off. Try a VW or a Crown Vic or Expedition. When you change oil for a living you get used to the birds and mustangs. Id do an oil change on a bird aa million times before touching a VW. Especially the new V6 Jettas.
i work in a garage too but when you dont always have access to a lift having a better filter location makes a lot more sense.
I have to agree. I have NO problem getting the filter off of my T-Bird. Sure, it's not as easy as getting one off a 3.8 on a buick (Yes, it's in PLAIN site DIRECTLY beside the oil pan bolt, and you can fit your whole hand around it on a 2000 Park Avenue).
But, I just go up and through a certain spot. I'd have to show it in a picture or something. And, then I bring the other back through there. After putting the adapter plate gasket on, I'm not messing with that area of the car UNLESS I'm changing the oil.
True, it really isn't THAT bad to swap oil filters, but no matter what you do, you'll spill some oil during the process. That fact, and the fact that I could run a larger filter by relocating it, was enough for me to move the oil filter to the driverside fender in my XR7.
-Rod
I bought the relocation kit and i hated it. Honestly it took longer to change that filter then it did with it on the motor plus it was cheap quality. I can get the filter off in about one minute these days so if you practice enough it gets very easy.
Will
yea first time was intimidating, when you have to LOOK for it you know your in for some fun. the more you do it the faster you get at it moving your arms in positions you never thought were humanly possible.
-Mike
CV's you just turn the wheels all the way to the left. The 4link steering moves the pitman arm and stuff out of the way so its easy to take out.
Isn't that the truth. I happened to have seen where it was in a 4.6 in a crown vic of my uncle's when we had it apart putting new headgaskets on. I was like "WTF is the filter doing THERE?"
That was before I knew I was going to get a Thunderbird. Even though I KINDA knew where it was, I still had to look.
Crown Vic is simple. T-Bird is ten times as hard.
Heres another thread for you discussing a cheap kit with 30" crimped neoprene hoses instead of rubber and hose clamps...
http://forums.tccoa.com/showthread.php?t=47028&highlight=filter
The kit is made by Trans-Dapt. $42.99 at Northern Auto Parts.
http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=9480
Actually I just checked and it looks like the same kit Summit sells for $42.95
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TRD-1127&N=700+400158+115&autoview=sku
Not sure if thats the same kit you were looking at on Summits site or not...
I use a Cobra oil cooler (water/oil heat exchanger) on my 96 - the type that mounts to the block and I still manage to get my oil filter off without much of a problem. Not fun though... A lot of oil spills on the K-frame, so I have to use some spray solvent to clean the mess.
Mitch
Agreed it's not terribly hard to get it on and off, just terribly messy.
Well, here's my $.02.
I put my filter relocate in about 4yrs ago now, and used Perma-Cool parts to make my own kit. I decided to use rubber hose and clamps to save $$$. Well, I did saveht e money, but a few weeks ago I started noticing oil on the ground under the car. The hoses stiffened up after time, and started leaking. :mad:
I replaced the hoses with stainless braided hose and AN fittings. Works fine, and looks better... :D Now, the cost is greater but I'd still say that if you're gonna move it, do it right the 1st time.
I put my filter under the front bumper, cutting some of the lower shrouding. I can replace the filter with all four wheels on the ground.
Peter M
It seems to me that all of yall are 3.8l and 4.6l owners. Try it on a 5.0l. It is a pain in the arse. Not just a little oil gets spilled. It is a freakin mess. That is why I am going to put one on my car.
^^^ judging from your description I'd say it isn't any less messy doing it on my 4.6L. You've got to dump the filter during the gymnastics of routing it out of it's cubby hole.
The couple of times I've done it I flip the filter around and try and plug the whole as much as possible by sticking my finger deep in it, then work it out as quick as possible. lol
They are all a pita to do. Owning a both types of V8s there's really no difference. The 5.0 you have three places oil will come out and make a mess. Actually the back drain plug drains clear where as the front will splash up against the lines directly in front of it and splash everywhere. So there's two potential messes. Add in a Mark 8 and it is a little more frustrating. I just put a pan under the cars and dump the oil out onto the K member since you have to flip it around any ways to get it out. Then use some simple green after I'm done and hose it off.
The Mark VIII makes it even worse? I don't have a problem with the front drain plug. Just the filter. I like to keep my painted garage floor clean. I don't like to mop. My K member seems to hold oil no matter what I do. I've even gotten some plastic from work and made a funnel type thing to catch the oil. It is even more of a pain.
oohhhhhhhhhhh man, I hate changing tbird oil filters. I went to do the oil change for the first time and spent about 30 minutes looking for it before I found the thing, going back and forth under the car, out the other side, looking for it from above, looking for it from below, and after 30 mins I finally found it lol
1 - 20 of 24 Posts
