In my 94 XR7 it appears there is oil in my coolant. :(In the resivoir there is a brown crusty substance just above the coolant level, as well the coolant is brownish looking. I flushed the coolant about a month ago and replaced it with antifreeze and water. The strange thing is there is no coolant in the oil and no white smoke.:confused: What could be causing this?
Even though you say it is brownish, and transmission fluid isn't generally brown, check your transmission fluid, however when my in radiator heater exchanger for the transmission went, it mainly filled up the coolant, but I changed the transmission fluid anyways, because they can't take any amount of water.
