Has anyone ever had there oil pressure drop all the way down when ever you are stopped at a traffic light or slowing down?
If anyone has I'm sure they've also seized their motors shortly after. If your oil pressure gauge (read: idiot light) is going all the way down when you stop or slow down, you probably have a bad sending unit or the connection to the sending unit is loose/corroded/damaged. Check it out. It's by the oil filter and has 1 wire going to it.
allright thx alot :)
mine dropped all the way down when it ran hot and blew th hg's. if you don't hear the "death rattle" you've probably got a bad sensor
Have you checked to be sure the oil is full?
Jay
mine used to shudder when at idle at lights. It would drop real low and bounce really fast. Id give it a little gas and it would go back up and clear up. After I changed out motors (and along with that all sensors) it stopped. Maybe I got to it before it locked up. But it did it for many years with no other symptoms.
