Anyone know if the oil pump would make any sort of sound if it was going bad. Or what the symptoms of an oil pump going bad would be?
Yes it will make a noise, by what I'm told sort of a grinding/whining sound. Obvious symptom is low oil pressure.
yeah i'm hearing a noise, i'm not sure if its the oil pump or the power steering pump (probably power steering). but my oil pressure is high. i would imagine because i have a good size oil leak im going to have to fix tommorow. thanks
