1 - 2 of 2 Posts
i'm sure this has been asked before but i'm to search for it. i'm just curious was all suspension parts off of a mark 8 will swap to a bird.
The spring perches in the rear are the only thing I can think of.
On the mark, there's a spot to bolt the bag; on our cars, it's a spring perch.
I believe everything else will swap; I know going the other way, the lower rear spring perch is the issue.
I think you have to use the mark bolts in the rear; the design is different on the LCA somehow. The bolts have huge heads...
Look at it; you'll see what I mean.
1 - 2 of 2 Posts
