Alright, down to the last bolts.
I could not find the Intake Plenum/TB torque specs. The 4 bolts on the plate with "4.6" written on it.
Also, on the intake, near the fuel injectors, there are little threaded holes, what goes into them? There are 4 on each side, but I have ZERO extra bolts, and I don't remember taking them out. They appear to go just through the manifold, not into the heads at all.
Any idea what I'm talking about? Did I completely lose a bag of bolts?
Brian
Fry Rice Specialist
those holes are for cop setup.
the plenum bolt is 7-12lb. ft.
cop set up....is?
am I missing something?
Fry Rice Specialist
coil on plug. those are on newer 4.6 and also certain mark 8.
ThunderBeast86 said:
cop set up....is?
Each plug has a coil sitting on top of it. The little holes are used to bolt each coil down so it won't pop off the plug. The benefit is that there are no plug wires running all over the place, just a connector similar to the fuel injector setup.
Rob
