I was pulling up to a stop (going downhill if that matters), and had a harsh 3-2 and 2-1 since I was pulling more vacuum than I have tuned for. After this, it seemed like the transmission was stuck in 2nd.
I am running a TCS... It's worked fine for a year and a half. It's commanding the shifts (or at least it thinks it is) at the right times... When I opened the glovebox after it immediately happened, the light was not changing colors to indicate a gear change... Possibly TCS?
Doubtful. There is no MAF or TPS... I made a T for the VSS, but it would have no load values.
k, thanks!
Would it be able to go into manual 1st?
