Do you have to replace the outer valve body plate gasket (small plate on bottom of valve body) when putting it all back together, or can you reuse is assuming it's in good condition? Thanks guys.
I asked the same question a while back....all I got was "why did you take the outer plate off?" :cool: I replaced it instead of re-using it...you really don't want to have to go back in just to replace a $12 gasket...do you?
I thought it had to come off, seeing as bolts go through it to hold the valve-body in.
I guess I'm just silly for removing all of them. :)
If you took it apart to the point that you're looking at the paper gasket you should probably replace the gasket. I did. :D Thankfully the Ford dealer that's only 5 minutes away from me had it in stock. I always try to start un-familiar projects earler in the day to account for those unexpected parts runs.
Marcus
Will do good sir, thanks for the offer. I'm still waiting on the stang VB from Dan. Then i'll figure out if that plate gets reused or not and if I even need to worry about this. I guess this is why I bought the service manual...
the torque wrench is your friend on those valve body bolts. There is also a torque sequence, but I didn't go that far, just torque spec.
JH
100in lbs is around 8ft lbs
And I bought the gasket.. Figure this.. if its coming out... and you have to release the pressure from the bolts on the gasket.. change it.
Who knows.. it might save ya a headache later on down the road.
check my article in WIP for torque sequence info.
