1 - 2 of 2 Posts
My car was running hot and i notice that the radiator hose was soft i could squeeze, shouldn't it be hot the car was it didn't feel any fulid running through it so i changed the water pump twice same thing. It's not moving any water. Can a Thermostat stop the flow of antifreeze. I tried to change the thermostat but i broke off the bolt so now i'm pissed just wanted to know if the thermostat could be the problem before it try to tap the broken bolt. No leaks, a lil white smoke but i gutted I the cats and i have a valve leak.
Lee
A stuck thermostat would cause those symptoms. It doesnt suck water through the top hose until it opens.
1 - 2 of 2 Posts
