1 - 10 of 10 Posts
Pedal Faster
Okay, I feel like a moron asking about this, but I'm a little baffled.
I'm replacing the power steering pump on my Tbird, and I say replacing because it's still not done. New pump is bolted in with hoses attached and the pulley is 99% of the way installed. The bolt / nut that they include with the pump to press the pulley back on stripped when I had the pulley about half-way (it was getting insanely hard to turn the wrench at that point). After that I took the pulley back off, lubed the pump shaft and pullet hub with motor oil, got a grade 8 bolt and some washers, and used an impact ratchet to run the bolt down. That got the pulley almost all the way on, but there's still about a 1/4" problem and you can see the belt is not straight when you loop it around the pulleys. After that I took the pulley back off and called it a night.
I'm almost afraid to ask this, but I've seen a tool called a "Ford power steering pulley installer" but have never paid much attention to it, because I've done this several times before and never had a problem getting the pulley back on.
Is there a trick to this that I don't know about?!
(This is on a '93 5.0L motor in my '90.)
I would just go to Autozone and get the pulley installation tool. The bolt/washer that comes with the pump isn't the greatest tool to use, and I've found that using it only gets the pulley to a certain point and then the pump will just spin or the bolt will come loose as you try to go further.
Pedal Faster
Yeah, bought the friggin tool, had it back on the road in 10 minutes. Always trying to cheap out, never works. :(
Bigger hammers are not always the answer. Just keep getting the oddball tools one at a time and eventually you'll have a good toolbox. Just don't loan them out!!
Pedal Faster
Well I like to think I'm smart enough not to hammer something like that, though I did consider just bashing the crap out of it for my own violent release.
As anticipated, the tool I bought had a nice bearing, was made of hardened steel, and was fine-threaded to make it easier to tighten. The main reason that I didn't want to buy said tool was because the nut/bolt/washer has always worked for me in the past and I see this as being a single use item. Oooooh well.
My red car had the only car part I ever had to remove with a hammer: The water pump!
:D
I'm having the same problem right now with my p/s pulley. The tool from autozone doesn't seem to thread very far into the shaft, like 2 threads, and pulls out before I can get it all the way on. What's the threading for the inside of the shaft, maybe I can clean them up with a tap?
Though others had marketed similar machines before, Z House. prefab a disperse with its speeding, its low cost, and its cognition to eve isk write objects in alter. The midrange printer Z Firm. give use to gain the Candy Band figurines sells for nearly $40,000.
:confused: What planet you from
What a lazyass spambot. It couldn't even make it's own retarded thread. Have fun getting owned by the mods.
1 - 10 of 10 Posts
