Hi guys, I need a little help. Decided to get my hands dirty this weekend :tongue:
I had my engine light on and using my scanner these codes came up
p0135
p0136
p0141
p0155
p0161
p0401
p1131
in this order.
I started with cleaning the MAF and now it fixed most of the coded.
What I have left is
p0155
p0161
Both 02 sensors on the drivers side.
I took them off and cleaned them with a torch... codes comeback after I start the car the second time.
Switched one of the sensors from the bank 1... no change.
Wiring and connectors on the sensors look good.
I'm not sure what else to try.
Can you suggest what else I should do? Thank you for your time!
check for vacuum leaks
Thanks for your reply Chris, I did replace all the bad vac lines when I got her, about 2 years or so. Will check again tomorrow though.
Just to add, the car gas no mods. Newer spark plugs and wires.
She has been a real good girl, took her CT to Florida and back, Maine, Indiana, 3 times to SD and no problems.
Just need to get rid of this engine light and I'll be a happy camper.
Hopefully its something simple...
