So the other day the ol' 97 threw a P1443 code that had to do with EVAP.. Replaced the canister, and a couple dry rotted hoses and presto! Good as new! CEL even turned itself off this time
...... Until tonight :')
Not only is it throwing the P1443 again, but now it's friend P0430 (catalyst not working properly code) decided to join. I did swap in a new Evap sensor because I thought maybe if the canister died, the sensor was on its way out anyway... No luck. All the hoses look fine. I can't find any vacuum leaks. Car drives fine, but you can smell what seems like an exhaust leak, or gassy smell from the passenger side though it's done this since I got it (my 96' did this the while time I had it)
Any suggestions? Just my luck that the car would do this the night before I move 6 hours away to a new state!
