i get a check engine light from time to time, and it is always a p1443 emisions code. called my buddy at the local for dealer and he says he just throw parts at them. canister, cvs valve or a bypass. well wich one is it? wondering if anyone has been down this road.
Trumpeter Extraordinaire
According to the 1996 PC/ED Manual, P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold.
Damaged EVAP canister purge valve.
Damaged PF sensor.
Here's a diagram to assist you in what to check:
Good luck to you.
