Has anyone every tried this tire size? The Michelin I want doesn't come in P225, so I figured I would ask in case someone has looked into it. The wheels I am using are 6.5" wide.
Thanks!
My tires are P235/55R17 as you know and there is no rubbing. I was concerned about the width being maybe a bit too much, but there is just barely enough clearance with the top ball joint on the front UCA... and I have 7" wide rims.
If you plug in the numbers my tires versus yours here http://www.miata.net/garage/tirecalc.html you'll see that your tires are 0.1 inches shorter (height/diameter) so you shouldn't have a problem.
Yeah, I didn't see your post until I started this thread. I used the same site to figure it out.
Awesome!
Baddest N/A NPI in Canada
I run 245/50/16 Bridgestone Potenza's on a 16x7 rim with no rubbing issues. I am pretty sure those would fit on a 16x6.5 rim...
I have that size; 235/60/16 on OEM sport wheels and they fit and work just fine.
makes the speed about 2mph faster than what the speedo shows, though
I run that same size myself. Fuzion zr1's
I bought my old '92 SC with the 235/60R16 size tires on it. No rubbing but the tires weren't as low-profile looking as the stock 225 size. They filled up the wheelwells but, to me, they looked a little big.
