I've been trying to find the paint code to touch in a recent rocker repair on my car.
I've checked under the bonnet, and the plate attached to the body lists the following numbers, in this approximate layout:
2375 P62L1
A
205525 RD 56
RH052524
FF
WL 4G844
From the tech article, I think my colour is "RD" - Teal. When I gave the code to a local paint company (over here in the UK), he found it on their system as "Bright Teal Green Metalic".
My car is the one shown in my gallery. Is that what the colour is actually called?? I'd have said it was blue/turquoise??
Yup, that sounds right. Color code RD, "Teal Metallic".
Yes, but Teal "Green"???
Not sure where that comes from, probably just a local database variation or interpretation of the color. You should be able to have them mix up a small sample of it for you before you buy any quantity to be sure.
Yes I think they do that. Ford didn't do any other "Teals" though did they? According to the tech article chart anyway?
Not that I'm aware of. The RD code was only used in 94 and 95.
You can confirm the paint code by check the tag inside the drivers door jam.
-Bryan
I will do, next time I get it out of the garage. I can't get to the door jam without moving a ton of stuff (my garage is only about 1" wider than the car!).
My 94 had the rd paint code before I painted it amber fire pearl. It was the only teal color I've seen on these cars.
