REGULATOR said:
I cant link to the article the the tech article section need help please.
I just tried it & it works. It seems to open up under the list of articles. After you click on it try hitting your tab & alt buttons at the same time & it should get you there.
that didnt seem to work. links from other posts to other articles work that but not by going through the articles page. probably just another problem with by laptop that might get fixed after working with dell(hopefully).:confused:
Disable any popup blockers for .tccoa.com. That could be your problem.
