I just got my first digital camera so I thought that I would give it a go. Here are the parts I have collected for my '02 Explorer swap.
First is the motor, detailed with new fuel rail, injector o-rings, solid motor mounts, and '95 T-bird belt drive. Of course, I couldn't resist the classic Ford blue paint.
Ford Racing Performance 3.73 Trac-Loc aluminum pumpkin. (Thanks to Dan the Man)
Dual circuit cooler for transmission and engine oil
And of course, the old '95 4.6
Some parts not shown but acquired:
oil filter relocation kit
J-mod parts including deep sump pan (thanks to Dan the Man)
'96/'97 fuel lines (thanks to Dan the Man)
Marauder torque converter
Still waiting to receive my '93 MKVIII driveshaft.
Exhaust; I am planning on true duals with no X-pipe.
Still have to order a chip.
What to you guys think?
Fry Rice Specialist
looks like the intake manifold is without the aluminium crossover???
Boom.
Good job! Just one thing I see...
It looks like you still have the Explorer t-stat housing on your motor; you might need to swap out to the T-Bird housing, not sure if there will be any interference or if the rad. hose will properly meet the Explorer housing.
Yup. I figure it's easy enough to swap the intake. If it goes out, I will swap it out. I questioned this decision on the boards before and one person replied that it will probably hold up. If you guys think differently, please speak up.
It looks like you still have the Explorer t-stat housing on your motor; you might need to swap out to the T-Bird housing...
The T-bird housing doesn't fit. I figured that I could buy a universal hose to fit, unless somebody knows of a housing that will work. (96/97 style?)
I used the 95 housing with double o-rings; one below the t-stat and one in the normal place. No issues so far.
On the oil filter/lower rad hose adapter, I had to use the 02 gasket. Someone else on here used the 95 gasket and had sealing issues. Just a heads up.
Rob
