Here's a pretty complete list of parts you will need to swap a PI intake on a 94/5 4.6. This goes in conjunction with the other thread(s) on the how to... This list is pretty complete minus the part numbers and prices. I only have the recipts, and the descriptions on the parts are not very good, and I bought a lot of the stuff used (as should you). Total cost on these parts shouldn't be over $400. Any competent parts dealer will be able to find you these things giving them the decription. If they can't, go somewhere else. A side note: The vac lines, fuel rails, EGR to plenum bolts have all been dicontinued by Ford, so you will not be able to get these new. So here you go. Any q's just shoot. If you want the whole tech write up and parts list in Word format, post here, pm me or email @ [email protected]
Enjoy
Parts List:
PI Intake w/aluminum crossover
NPI Gaskets
96/7 EGR and Tube with vacuum regulator
96/7 Upper plenum and throttle body
02/3 GT Intake tube with 80 MM MAF and Air box
PI alternator bracket
PI water bypass tube in valley
PI water pump nipple
96/7 Vacuum lines
PCV tube
96/7 IAC valve with IAC inlet valve and corresponding hoses
96/7 Fuel Rail
96/7 Fuel lines from rail to filter
Fuel Filter
96/7 Pigtail for IAC Valve
96/7 Throttle cable
96/7 Throttle/cruise control cable bracket, spring, and corresponding hardware
Throttle body to upper plenum gasket
96/7 IAC gasket
96/7 EGR Gasket
96/7 Thermostat housing
PI Thermostat housing bolts
180* T stat
T stat gasket
Water Pump gasket
96/7 IAC to upper plenum bolts (2)
T body to upper plenum bolts (~16, you may not need all of them, as they are for upper plenum to intake as well, and fuel rail)
GT MAF wiring pigtail with 6 wires
RTV
You will also need some lengths of hose (not more than 4 ft each) for various connections
You should be able to find most of these parts used, but as for bolts and gaskets, etc. you may need to buy new.
Enjoy
Parts List:
NPI Gaskets
96/7 Vacuum lines
PCV tube
96/7 Fuel Rail
Fuel Filter
96/7 Throttle cable
96/7 IAC gasket
96/7 EGR Gasket
180* T stat
T stat gasket
Water Pump gasket
RTV
