1 - 2 of 2 Posts
I've been having this problem with my car since I got it. First off, when you open the passenger door it drops a little bit...... is this the sagging doors I've of? and how do I fix it?
Secondly, the trim panels on the outside of that door are coming loose right at the edge, and when the door opens it gets caught between the door and fender preventing the door from opening.
Would it be easier(and better looking?) to just remove those trim panels on my doors? or should I look into fixing it?
Look up hinge pin/bushings replacement. Common problem due to our heavy doors. Panel is catching cause door is hanging too low at rear when opening/closing. Fix the pins, then fix the trim.
1 - 2 of 2 Posts
