I finally got around to installing the SS brake lines (from the group purchase a while back) on the front of my car. I already have PBR's installed. When I put the banjo bolt through the brake line and two crush washers I can only tighten them down until there is about 1/16" space left but the bolt feels tight. Upon inspecting the bolt I found that the 3-4 threads closest to the head of the bolt are flattened so I thought that I must have over-tightened them before.
It took two days to get new bolts from a local dealership. (They tried to charge me $21.73 each, but I made them take $12.50 each!) I looked at them and the same threads are flattened out so I guess my threads are okay, but the bolts still do not go all the way in. They won't go past the flattened threads.
I know that they are not hitting the piston because I pushed the piston out some and they still do the same thing.
Did anyone else have a similar problem? If so, how did you resolve it? Can I put extra crush washers in? Seems like that might not be safe, but I don't know.
Geez, this was supposed to be a couple hours of brake job/upgrades on Saturday and it's turning into a weeks long project.:bangwall: :boom:
