I believe my 1997 3.8 needs a PCM. I get a cam position sensor code even after replacing the sensor. Another 97 I had did the same thing. PCM was the issue. Mine is #F6SZ12A650AF. I found on F6SF code on EBay. Will it work? What's the difference? I remember seeing on here someone could flash the units for stock or improved performance. Can this be done? Who was it? I am in 37412. Thanks.
You want to match the 'catch code' that is on the PCM. It is a 4 digit alpha-numeric like shown in the pic below. Otherwise, one with the same configuration (3.8NA/4R70W/EEC-V/OBDII) should work but it may have a slightly different tune. I have the RCX4 unit that is shown if you think it will work for you (from a 96/97 3.8L Thunderbird/Cougar). Dave Dalke over at Super Coupes Unlimited sells and does mail-order tunes for the SCT chips.
Easy to check, open the hood and the code is on the passenger fender.
Al
Thanks. That is easier than pulling the PCM out. Any idea where it it on the fender? I don't remember seeing anything.
If it's the original fender, there should be a sticker with the code on it near the hood hinge.......at least that's where mine is! :tongue:
Yeah, it's original. But twenty years old! Will try to look tomorrow. Thanks.
