1 - 15 of 15 Posts
Are these cool and did I get a good deal? Plans are for my '96 current npi heads and future pi intake. Let me know what u guys think.
pi cams
Baddest N/A NPI in Canada
That is a good deal for PI cams.
MaleWhore
that is a really good deal...thats what i was going to buy but im looking for cams with bolt on sprockets since im lazy and i am taking the risk of using the cam removal tool....
Refrigerator Raider Hater
they look lie they are press on to me, which means you can't just use the cam tool, you'll have to take off the PS pump, front cover, etc.
Yep but for that price ... damn good deal ... i paid 120ish for a set. then sold for 80ish. They usually run around 100 +-20.
I have no issue re-selling them back on the bay. Should I then go for the bolted sprockets instead?
I would, unless your in a hurry to get them. With bolted cams, you'll need to buy new bolts, but then you either use the tool, or if you see something wrong, you can still open it up. Bolted sprockets just give you the option.
yeah, no rush at all, i just kinda rushed at the price without much thought. bolted cams it is! thanks !!!
At that price :D I would have also !!
I just swapped mine over in November with the pressed on sprockets
Did it by myself and it is a lengthy job :tongue: Mechanical Knowledge
is a must !!
Another thing some cams have been damaged when shipped if
they are not properly packaged :(
is a must !!
well see that's the thing. Is it really that bad? I mean I just need a little more patience ad need to remove a few more things right? I might just end up keeping them. :confused:
Its not really that bad installing them. It just take a lot more time. Me and a friend did the whole job in three days working only after school, in the meantime we installed the pi intake, accufab 75mm throttle body and plenum. Good learning experience too. Just make sure you read up on it, especially the timing.
yeah I saved the timing article from MD in my favorites :)
are there any good write ups/articles, did a search, but nothing that I really looked for :(
1 - 15 of 15 Posts
