Is there any difference between a stock 94/5 Cam and a 99+ PI cam? would it work with stock everything else? Any gains to expect? The only reason i am asking is because someone local has a set for sale for $10..... just curious, looked for a little but but did not see any post's that were similar?
Yes, they are different. No, you cannot put PI cams in your heads without some machining, if I remember correctly you will run into valve spring issues unless you machine the heads.
They work in 96+ nPI heads.
There are lots of PI cam posts.
ok thank you... all i needed to know
if they do not sell on there shoot me a PM.... i have a lil bit right now but would need to save a bit more and with football season all so close my hours get less at the job.....?
