1 - 13 of 13 Posts
Has anyone written a Tech Article for doing a PI Engine Swap? I have seen a couple "Vague" ones, but was hoping to find a more in depth article... Or if anyone in SoCal has done one, and wouldn't mind helping for a weekend????
The PI Head Swap article is probably your best bet. Covers a lot of the other stuff you will need to buy besides your PI engine. Much more needed to do a 95.
Boom.
Tim and I loosely started one focused on the Explorer engine into '94-95 cars, but it hasn't been completed. If you need specific information, you can feel free to PM me, TimB, Cam94, or Aaron K. I speak for all of us when I say we're always willing to help someone doing an engine swap!
Thanks for the help guys, I will need it. My motor should be arriving today, but I plan on rebuilding before I put it in, so it may be a month or so before I am ready to install. Palmguy, I will definately be bothering you on a daily basis!:D
Unless someone has found a way to adapt the cruise control from a 94-95, you will lose that with the swap. I was going to attempt to swap it with a 96 unit but have not done it - requires some rewiring.
02 Explorer Pioneer
My 94-95 cruise control works just fine on my PI motor. Just cut the little red tip off the cable and you are good to go
Sweet T
Ya need any help wrenching on it and I'll try to give you a hand. Though the gate guards might look at me funny if I roll up with a Navy Sticker on my windshield and then ask for a visitors pass.
Same here, although not PI motor but 96/7 upper (same thing)
BTW I am working on an article for a PI intake swap to a 94/5, a lot of that is what you will need I am assuming
Lol SD, I am sure you will be fine. The MP's see alot stranger things come through that gate... :D I have never swapped a motor before so this should be an interesting adventure. I figured, Hell, I rebuild jet engines for a living, how hard could this be? That being said, if you would lend a hand SD, it would be greatly appreciated. I will be ready with cold ones in the fridge.
After eight years of owning the car, I have yet to actually USE the Cruise Control. I am thinking it won't be a problem if I lose it, but it would be good to keep it working in case I ever need it.
Awesome Joe!, Will you be posting it in the tech articles section or on a private webspace? Let me know when its done!!
Sweet T
Just lemme know and I'll bring my toolbox.
I'll post it up here somewhere. It should been done soon, hopefully. It has been started.
1 - 13 of 13 Posts
