1 - 10 of 10 Posts
I have a set of pi heads that have been ported with valves,springs, retainers and keepers
the valves have had a 3angle job done
Im looking for $350
I traded my 4v heads for them the guy that owned it before me worked for comp cams he did the port work at there shop i cant rember the part number of the springs and the valves but they are comp I sent a e-mail to the guy last night he can firm up the rest of the info if it helps he was bulding it for a blower
do not have the flow numbers on the heads but it should equal to a stage 1 to stage 2 port job. The springs are Comp Cams but I do not know the part number. but they will handle .550" lift because that is size cams that I was running.
they have the swirls cut out (USED FOR BLOWN ENGINES ONLY) well they will work on NA but not very well
I will be at the shoot out with them
i will get pic ill meet you in C-bus on E11 ave (JEGS) and will check shipping tonight
asap daddy needs a new pair of shoes and by shoes i mean snow tires
however this weekend im going to the shoot out so i could meet you wednesday or thursday
sure as long as its good :D
sold
1 - 10 of 10 Posts
