1 - 20 of 52 Posts
Sitting in a box back in my shipping department.. waiting on a few other parts then I'll load that stuff up into my car...
I believe i'm going to try and do the swap tomorrow, I should have time.
I'm picking mine up tomorrow as well, and then driving straight to the dyno to get some numbers before I put it on. Stay tuned.....
I won't have a chance to dyno before and after..maybe after... but I also have PI cams too.. and I haven't dyno'd since those were put in.
The only dynojet in town is owned by a moron, and he's not going anywhere near my car.
My weekend...
For 97 owns you just need the gaskets, intake and that tube you see in the pic, which is the coolant tube.
You can also see my 180 t-stat and my 22c plugs that I need to get in there yet too.
Still trying to figure out my best route for getting that coolant sensor hole drilled. I might just drill/tap it myself without a press... or i might just splice it... not sure yet...
i saw on an Ebay auction that the PI aluminum Xover has a specific part # (RF-1L2E-80368-AA)....i don't know how true this is, but maybe the revised NPI intake has a seperate part # for the Xover with the holes for dual sensors? ....of course drillling and tapping would probably be cheaper, but its just a heads-up for those who might wanna look into this
guitar maestro said:
i thought you were supposed to use NPI gaskets?...at least that's what i thought i read at MD
Yeah you are... I just took those pics after I took those out of the box... well ****... Dan sent me the wrong ones. That sucks. But it's my mistake, I never really told him which ones I needed. Not a big deal, gaskets are a minor thing price wise.
Aaron K. said:
Intake gaskets are reuseable...just be careful when you remove your NPI manifold.
Yeah, but you shouldn't. I'll just go to the local Ford dealer and get ripped off. Not much of a choice I guess. Not worth risking anything over $15 in parts.
High-Mileage 4.6L Thrasher
Shouldn't what?
Reuse intake gaskets?
They're designed to be re-used and it's not an issue.I'm using the original intake gaskets that were on my car when it left Ford's assembly plant.
And I'm on the third different intake manifold.
JL
Johnny Langton said:
Shouldn't what?
JL
I've always heard that you should re-use them. Guess it's just another one of those myths.
Mine is just going to get set to the side for a little while, until the heads are finished, and I order the Comp Cams. I'm not really in a hurry, just gathering parts, and trying to get this new shop to work in, so I'm not limited by their hours.
I've "had" mine for about 4 days now, I've been too lazy to drive to Joe Cooper to pick it up, but I'll get there tomorrow morning, since I don't have to work.
Does the PI intake need to be drilled for a 1995 T-bird or is that just for '96-'97?
Discussion Starter #20 (Edited)
Any pre 99 4.6 will have 2 coolant sensors, 99 and up only has one. So yeah, any Tbird will need that hole drilled.
Although I believe Crown Vics had one from 98 up.
1 - 20 of 52 Posts
