Hey Guys,
I just started to do my PI Intake swap, about 5 hours into it.
Noticed my NPI gasket had a leak and had been crushed causing my coolant leak. lol. but i got this far with the PI Intake swap, theres no turning back now
I noticed the Heater Valley Hose is attached to something behind the engine, i thought it was the bracket which i had removed (holds the DPFE sensor as well) but I did a few searches and people are saying there's a SATC sensor attached to the hose or something? I need a bit more confirmation on this because if so, I will just rig up my own heater pipe.
If i wanted to make my own heater pipe what would be the best way of doing that? Should i work with the stock Nipple. or still replace it to the PI Nipple? Should i use a pipe cutter and attach the NPI heater hose to the PI heater hose. I will also need some Rubber heater hose to create something like that. But one thing, would i need to create a flair on the end to ensure that the hose doesn't slip off? i noticed on every hose connection its flared.
One more thing, I read someone used a impact hammer to remove the pi nipple. I have one but i was thinking it would damage the nipple. Is there something i should be cautious about when doing this? I cant find my BFH
i dont kno where it went.
Please get back soon guys
Thanks
Kyle
Thanks
Kyle
