1 - 13 of 13 Posts
Chapter Director Coordinator
hey you PI intake swappers
so far, no probs but..
after driving for a bit, i pull into parking spot and pop her in park, and the idle drops to "drive" level, around 600-700rpms.. normally she is at 900-1100rpms while in park
any clue?
Some reason mine idles at 950 rpm bone stock, and with the a/c on.
Discussion Starter · #5 ·
twas a new iac since... um... my cam swap, i think.. maybe before.. and was idling the same even w/ the new iac as it was w/ the old one.
how the hell you clean those damn things anyway? no one has been able to give me a straight answer heh
Preston told me to use Carb cleaner not brake cleaner, unbolt it and spray in to the little bypass doors...
joseph
Mine shudders when on a cold start from 700 and then pops up to 1.2k and idles there until I put it into drive then it idles around 900 or 800.
jamesD
Hope my info helped with the water pump?!?!?! Never heard if it did or if it hurt? Don't worry about the idle for a bit, Comps still trying to figure out what's going on. My would drop down to around 500 and now she's slowly climbing back up close to 1k.
Enjoy the new intake!!
Discussion Starter · #11 ·
ya.. it wouldn't come out.. i just chopped it off a bit more w/ my pipe cutter, and put some heater hose on, double clamped it and called it a day.. 2.5days for an intake swap is ridiculous, especially when day 2 was spent half pondering how to do it, and half dodging rain drops heh
when i accel to 60mph moderately, it feels like there is a crap load more power waiting to come out up until i let off the gas.. definite different beast..
we shall see HOW different @ moroso and on the rack the day after :D
No idle issues here, idles just like stock. Check the IAC and check for any vacuum leaks.
1 - 13 of 13 Posts
