1 - 20 of 26 Posts
So would a 2002 PI motor out of a Mustang GT bolt to my '94 tranny? or would I need to swap tranny as well. Would a 1999 4R70W auto tranny also out of a mustang swap right into the Bird (V8 '94 LX). Other than the wiring harness and ECU what else would I need?
Sam
Thanx for the link. I read the entire thread. So the motor out of the 02 stang would be a direct bolt up to the tranny, but would require some alteration to the motor mounts? If you don't mind me asking how much was the explorer engine? If I had the if I had the harness and ECU I wouldn't really need a chip would I? I apologize for my stupidity when it comes to mechanical stuff, I am learning though... If someone doesn't mind answering a really stupid question, what would be the benefit of swapping to the 02 motor other than the lower mileage newer motor...
Sam
02 Explorer Pioneer
Mine was $1000 but they seem to run around $1200. The main benefit is the newer motors have PI heads which means another 40 HP over what you currently have.
Thanx for the assistance timb. So is there any reason to not go with the mustang motor? Also does anyone know if I would need a chip with the ecu and harness from the stang? I appreciate all the help I can get.
Sam
Not anymore. I've seen timb's car. It looks like a good job. I just can't wait to get a ride in it. Also timb, did you ever think of a price for the pulleys?
The main advantage of the explorer motor over the mustang motor is that the '02 explorer motor has an aluminum block. This is only true of the '02 year motor.
Both motors have the PI heads and cams.
Blown94SC said:
I just paid 900 for my 2002 explorer motor with 13.5 K on it...
Im looking into getting one. May I ask where you got one for 900? All I could get it down to is 1095 shipped.
-Shawn
I know this is probably a stupid question, what is the advantage of having the aluminum block?
Sam
And another stupid question, advantage of 6 versus 4 bolt??
Sam
Discussion Starter #15
What do you mean stronger? Is it bolted to the frame stronger, will it be able to handle more power like a sc, etc... I apologize for all the stupid questions.
Sam
02 Explorer Pioneer
Yes the block can handle more power without deforming. Note that the stock pistons or rods will not though. In general they are also cheaper than mustang motors
Fry Rice Specialist
i'm looking at this 2002 mercury mountaineer engine with 3k miles on it shipped to my house at $950. is this ok?
will it just bolt right on to my 94 lx?
i know i need 97-97 fuel rail, fuel lines and throttle cable and misc gasket, is these parts from t-bird or mustang?
how about my transmission?
bolt right on with my stock one?
this is the question i need to know after using the search.
thanks a lot.
Fry Rice Specialist
also will my stock ecu will run fine even with the pi heads?
my ecu pn is f4wf-12a650-ad
also wonder if the difference behing the 2 letters will affect the car?
02 Explorer Pioneer
Sounds like a real good price. The 96 - 97 parts you need are tbird not mustang. Yes everything bolts right up you will use the flexplate off your tbird motor and the motor mounts and it will bolt to the trans without any issues
1 - 20 of 26 Posts
