1 - 16 of 16 Posts
Sale is pending
I have everything needed to do a PI swap on a 94/95 car.
Windsor PI Heads/Cams and Valve covers
Ceramic coated Kooks headers
PI intake with aluminum crossover, modified for the two temp sensors
19lbs injectors, fuel rail, throttle body with complete vacuum hose routing
Complete modified engine wiring harness
96/97 throttle cable, egr tube, engine bay fuel lines
PI oil dipstick/tub
Mustang intake tube and 80mm MAF with 6 pin connector pigtail
PI Heater tube with custom hose/tubing to original location
The larger bolts for the timing chain cover
Superchips chip that will need to be reburned, It has a stock tune in it.
The above was on my car for three years, about 15K miles. The heads/ intake were used when I got them, total miles unknown. This is the complete setup, minus new gaskets and head bolts.
Asking $1400 obo plus actual shipping from 32907
Andrew
How come you’re selling them? Just curious.
One And Only!
would you be willing to seperate kooks headers?
if so how much?
DIBBS!
I was hit in the rear fairly hard, which totaled the car. I would like to keep this as a package set. I have it listed as a "best offer" and we will see what happens. So all you guys drooling over the Kooks will have to pray nobody else bites.
any chance you consider just the headers?? I could use a pair
did you sell this setup?
bump this, I wouldn't mind picking over this lot I haven't finished picking up all the PI swapping bits yet.
i wanty headers!
PM Sent about the headers. I need a set of these, my big bore is constricted with stock manifolds...
Pete
Anybody home?
Yeah, but people can dream :)
Pete
1 - 16 of 16 Posts
