Well I got the swap done...
Best so far was a 15.3 @ 88mph
Mods done:
PI heads
PI Intake
Custom Exhaust
Jmod
373s w/ trac loc
That is pretty much the extent of it..
I have a gt intake tube and airbox along with a LMAF 90mm to put on..
Is a dyno tune needed? if so what should i tell the guy to do?
Eleventeenth Gear Poster
Did you run a 15.3 after the PI swap?
You will need a dyno tune or at least a chip if your gonna add an LMAF. It would be a good idea to get one anyway with a head swapped car.
You need a tune, with those mods you should be going faster. I'm going 15.2-15.3s without the wide tires you've got and without the compression boost or PI cams. I suspect you'll drop a bit with proper EEC tuning.
Boom.
Not to mention the 3.73/J-Mod combo (optimize shift points/revise speed limiter)...
def dyno tune, you may not need a dyno tune, you would probably work out fine with an off the shelf SCT tune
FordChip may be having a tuning session in Cleveland soon !! contact Pat via
e-mail [email protected] From what I heard these guys are GOOD and
will know what are birds want !!! I need a dynotune also,maybe we can get
a session together - Let me know
Curt [email protected]
By the way, what are all the other times on your slips?
