1 - 15 of 15 Posts
Hello...I'm planning on getting some injectors (30lb/hr) and I am unsure whether or not I'll need new pigtails to run the injectors. Or fuel rails, even.
They are for a PI engine. Will they work with my stock 94/95 setup?
Ghost
Why are you changing injectors? Stock 19lb injectors will support to around 280 rwhp.
-Miller
02 Explorer Pioneer
Agreed. I ran my stock 94 injectors on the new PI motor before swapped on the blower
i dunno, because i got a good deal?
02 Explorer Pioneer
How good a deal is it when you have to pay to have a chip burned so the EEC will accept the injectors. Also your stock fuel pump will not support 30# injectors if you ever go with a PA
/already has a eec tuner.
What's a PA?
power adder
well, i got a good deal on a set
now i have to save for a larger fuel pump but i reckon you can probably guess where I am headed w/this.
Anyhow, for the meantime, are they usable with my stock bits?
then they're going off into my box of "save for later" stuff...
I have a whole NPI longblock with my name on it that's free to me.
nobody answered the question though -- will the injectors from a PI engine work for a 94/95 fuel rail?
02 Explorer Pioneer
Yes they will fit and work as long as you have the tuner. That said the big disadvantage of using a larger injector when you don't need it is that they are not as accurate at metering fuel at idle.
1 - 15 of 15 Posts
