Flow's!!! the best of course
It is the rear section of the Flowmaster kit from Summit Racing P# FLO-17111 i believe, you are supposed to buy the resonator with it also but if you do that you wont get any sound at the rear, which would make buying flowmaster useless....all you have to do is have a cut out the resonator, make a Y to fit there and the rest is beans & gravy, i had my clamped on just in case i didnt like the sound i could take them off and put different mufflers on.....i havent really had anyone drive it hard enough to get the true sound out of them....it rumbles the inside of the car....but if you have a K&N cone filter, after about 3500 RPM the intake noise takes over the mufflers noise, just a though for anyone thinking about flow's.....and also......those with 3.8, which is what mine is....there is no where to hang the mufflers where Flowmaster has the hanger, your shop will have to make one up.......im pretty sure im going to cut the angles off the tips and put some chrome tips on....gonna be kinda hard with bumper clearance.....plus the shop put that one hanger on the pass. side tip..which means it will have to be moved anyways.......thanks for the input guys.....i am real pleased with it......didnt give any low power that i can notice but it gave me lots of top end power....just dont be too heavy on the gas or you'll see that tank drop quick!!
(edit)
BTW......flowmaster uses stainless steel i think....which shouldnt rust....only the welds unless they were coated too....im not too sure though
