Here's my crossover:
And my oil pan:
44645
And in close on my crack patch:
44647
and another
44648
One more of the patch:
44649
The steering mod:
44650
The Mark airbox front half, the filter and MAF assembly bolt into it
44651
Here is the condenser/AT Cooler hookup:
44653
and some fresh paint:
44657
SuperNewbie
1995 Thunderbird LX 4.6 red
Its nice and clean. I like the braided Power steering hose. What modification did you make that required the big patch panel on the firewall?
Discussion Starter · #3 ·
Super,
The firewall patch is to repair several cracks around the heater core and bulkhead.
I want it to stay put until I can get the Roll Cage in the car. That is scheduled for next Spring.
My presumption is that the cracks occurred after I did the rear end, transmission work and wheel/tire upgrades last year. The car used to simply spin or if traction assist was on, less.
With the gear change, Trac lok, 275 tires and lowering the car, it hooks now. You can feel it twisting the chassis as torque is applied, so I assume this is the reason.
Along with the patch, I made up a pair of braces to connect the subframe to the cradle, hopefully those will clearance okay when assembly is complete.
Right now, the car is ready but I am still working on the engine, awaiting some parts.
RD
Discussion Starter · #7 ·
It's rained a lot.
I have the transmission ready to come out tomorrow. Hopefully the plate I made for the floor jack will work out and I can delete the forklift. I hope to lower and roll it back enough to R and R the converter properly. Then get the studs lok-tite into the converter and align it for a proper union.
Lotta work, but I am thankful it is no mystery and I got the advice I needed.
