1 - 11 of 11 Posts
If it's a paint stripe, acetone will remove the 'residue', but it'll also remove the wax.
Or, if it's a tape stripe - try 'Goo-Gone', or even WD40. Either way, you'll probably have to wax that area again.
Apply with a 100% cotton cloth, anything with polyester (plastic) WILL scratch your paint!!!
kmart blue light special
$0.25 for a bottle of finger nail polish remover.
and a rag
took it right off, along with the wax and everything else around. but i dont care im gettin it painted. lol.
Discussion Starter · #4 ·
MadMax-
:D I'm not just ready to paint yet. ;)
Merc-
No Goo-Gone handy, but have WD-40. I figured some sort of mild solvent. Probably just a small amount would do it, huh?
I just waxed and polished a month ago. Not looking forward to doing all over again, but all it can do is help.
Thanks Guys.
DON'T use acetone in the strength...
soop said:
MadMax-
Merc-
Thanks Guys.
that you get it in from a hardware store. Use Goo-gone or just
plain cooking oil, your fingernail and plenty of rubbing....
TSTaCC President
goo-gone
Won't the go-gone mess with the paint though? I tried using rubbing alcohol to take the dealership vinyl stickers off the back, but you can still see them in the right light(probably just the paint). I was thinking about goo-gone but was afraid it would mess with the paint.
No it won't harm the paint..
I used it to get some serious adhesive off my rear deck lid
when I debadged my 'Bird. It has little or no hot solvents
in it to harm paint.
If you see any paint distortion - it won't be from the
Goo Gone. A light "cleaner" out to blend everthing
together if the newly exposed paint happens to look
slightly different.
Hope this helps,
I never had good results with alcohol
but one thing I found that worked really well was that 3M tar, wax, and adhesive remover (I think they actually label it as wax stripper). Problem is it costs like $5+ for a little 8 or 12oz. can. However, after comparing labels I found that it's really just laquer thinner. You can buy that stuff much cheaper. I honestly don't know what it costs myself, as my dad is a painting contractor and I just use whatever he's got handy when I need it. You should be able to find it at most hardware stores. Hope that helps.
Gunk Remover
Good ole Ronsonol lighter fluid works great too.....and doesn't harm the paint like an acetone based product would
I used a wheel that chucks in my drill - $17 at my automotive paint supply store. Works like a charm on the tape stripes and decals. Only problem I had was my drill wanting to get hot.... It looks to be made of the same stuff as an eraser only a little harder. Don't have name handy for the one I bought but 3M calls it a Stripe Off wheel and the boat supply place wanted $50 for the 3M version. The guy at the paint store seemed to be familiar with the 3M product and sold me this other instead.
1 - 11 of 11 Posts
