1 - 2 of 2 Posts
My pinion seal on the differential is leaking and I was wondering what torque wrench everyone uses for this repair. The repair manual references a spec of about 15 in-lbs of torque required to turn the differential with the wheels and calipers removed. So far I have not found an inch-pound wrench that goes this low. Also what torque spec did anyone use for the pinion nut. The mustang book I have references about 140 ft-lbs but the tbird book implies you tighten the nut until you reach the orginal inch-pound reading for rotating the differential. Overall i found this method to retorque the diff flange nut very confusing and i do not understand why ford made it this way. If you have any advice on this let me know. Thanks.
Will
Just do it by feel......until you reach the 15 inch pounds.
1 - 2 of 2 Posts
