is there supposed to be play in the differential housing? when i took my car into my school auto shop and put it on the lift, i tried to check the differential fluid. But the plug wouldnt budge, and i couldnt check the fluid. Anyways when i was trying to get the plug off i noticed that the whole differential moved as i tried to get the plug off, is this normal? im thinking it might be because of the IRS? correct me if im wrong, thanks
The differential has three rubber isolated mounts. It should be able to move a little to absorb the 'impact' from launches I believe.
unless you're using somthing like a 3 foot breaker bar, you relay shouldn't notice any play.
