morning gang 1996 cougar 4.6 stock throwing po420 replaced all o2 sensors still throwing code is there a cheaper way to fix this other then cats? thanks
P0420 or P0430 is always a bad cat. O2 sensors throw different codes. If you want to just keep the light out, you can buy spacers to space out the rear O2 sensors, which will trick the computer into thinking the cat is working, but eventually the cats will have to be replaced.
No problem, I didn’t even notice that. I just went and deleted the other one. Thanks for letting me know about it.
