1 - 2 of 2 Posts
I am thinking about drilling a hole (or two into the wider ones) and putting a grease zert on there. Think it would help? Or is that a horrible idea. I am referring to the bushings for the mounting points of the control arms mostly.
Discussion Starter #2
Eh, nevermind, the bushings weren't causing the problem. The sway bar appeared to have clearence, but then the car settled down and it ended up hitting the metal that drops down from the frame rails right above the bar. Sawzall to the rescue.
1 - 2 of 2 Posts
