OK, well, I had the radiator flushed, new prestone 50/50 running thorugh the system, car running, all is good...then I saw something drip down onto the driveway...it came from just in front of the crossmember...and it is red...would this be a power steering leak?
IIRC all the power steering lines where changed pretty recently on this car...so if everything is new it shouldn't be THAT major, any suggestions on what to look out for?
thanks
Mine has a small PS leak coming from the pump pulley that makes its way down the K member, That would be the first place I'd look since the lines were replaced.
Also, does your car have an external trans cooler? If so there could be an ATF leak from the spliced lines.
no trans cooler on the car....do these cars have a trans cooler from the factory?
Yes, it is in the radiator. The hard lines run past the motor mount on the passenger side.
