1 - 2 of 2 Posts
I don't know if this has ever been discussed but i need to know if i am having a major or minor trans problem. I will be driving on the highway and the car shifts fine and i will slow down, then as i press the gas the engine revs but the car keeps slowing down. I then let go of the gas then slowly press the gas and the car shifts fine. This has happened on a couple of occasions on and off. the trans fluid is fine level wise and color wise. What should i be looking for to solve this and how much would i get charged if i take it to a shop. Thanks in advance for the help.
Discussion Starter #2
Just to add this morning when i started driving the car wouldn't shift to 2nd gear. I pulled over shut off the car and waited about ten seconds, then started it again and it was back to normal. Is this a sensor or electronic problem.
1 - 2 of 2 Posts
