Yessir. Well maybe 140 lawl.That's a score!
Do you plan on using the entire speedometer?
I want to swap the faces out for black faces with the translucent numbers for the light to shine through. It's probably hard to find but I'll keep looking. I also saw some nice incremental guage faces that looks like some out of need for speed.The 8k tach transfers over as well. You'll need new gauge faces though, as the warning lamps are in different locations on the Taurus faces and the PRND2L portion should be eliminated. Scott Hrbacek was the "go to" guy for new faces for years and years, but I believe he stopped producing them a few years ago.
Look at what I came across.. 🤪👹The 8k tach transfers over as well. You'll need new gauge faces though, as the warning lamps are in different locations on the Taurus faces and the PRND2L portion should be eliminated. Scott Hrbacek was the "go to" guy for new faces for years and years, but I believe he stopped producing them a few years ago.
Right; neither Taurus faces nor MN12 faces will be correct. You need a custom made set.I want to swap the faces out for black faces with the translucent numbers for the light to shine through. It's probably hard to find but I'll keep looking. I also saw some nice incremental guage faces that looks like some out of need for speed.
Look at what I came across.. 🤪👹 View attachment 41341 getting close to finding 150mph glow swap outs. As you stated before, the other indicator symbols are in an different place for the bird.
This is what I did.I want to swap the faces out for black faces with the translucent numbers for the light to shine through. It's probably hard to find but I'll keep looking. I also saw some nice incremental guage faces that looks like some out of need for speed.
Look at what I came across.. 🤪👹getting close to finding 150mph glow swap outs. As you stated before, the other indicator symbols are in an different place for the bird.
Perhaps. If I get the right aftermarket set.Do you plan on parting out your Taurus cluster if you manage to get those white faces?
Worst one I ever saw was this, coincidentally also involving a Chevy Equinox. I wasn’t as close as you, but saw it happen from across the bay sitting on the balcony at the hotel I was staying at on the beach side, had a direct view of the causeway, the bus looked like it got air when the Chevy hit it, and watched the whole rescue operation. Chevy driver later died, luckily there weren’t any kids on the bus which I didn’t know at the time.I took this today when traveling to one of our sites today. It's not the first accident I've seen, but it's definitely not the worst. I can say that I've seen one where it was obvious the vehicle occupant(s) didn't make it. Then there's another where the driver may or may not have made it, but if there was anyone in the rear passenger seats it was clear that they didn't make it.
Anyway, the black Chevy Equinox and the white....Civic?....in the back parking lot in front of the Dominos there was teh other car involved. Either one car ran a red light or both were making left / right turns and weren't paying attention.
Yeah, I knew I had fuel pressure (there's a fuel pressure gauge under the cowl) and I could tell it wasn't getting spark by the sound of it, so I had a pretty good/hopeful hunch that it was crank sensor related. And thanks! I blew the truck apart about a month ago to install a Vintage Air setup during a 25-day vacation from work. Unfortunately the kit arrived here 29 days late, 4 days after I went back to work. :/ I did get the inner and outer fenders painted, as well as a bunch of work done on the Buick, though.Good to hear that you could troubleshoot it so quickly. Truck's looking good!
I was really really glad that it fired right up after I touched the crank sensor connector, as I was contemplating whether or not it was going to be worth the effort to push the car out of the shop, turn it around, and push it up onto the lift. I wasn't looking forward to pushing that heavy ass car around either.I had a splice in the wiring to the CKP go bad 3 blocks away from home once, me and a really helpful neighbor I had never talked to before helped me push the heavy beast all the way back to my house. I felt so relieved once I figured out the problem(albeit bittersweet because it was of my own doing)
I did call a plumber. But they're closed until Monday. Their Sunday rates are exuberant, lol.You should call a plumber. 😂
No cleanouts ? Those guys dont use tee fittings, just san-tees and combos. Your snake might be caught on an obstruction or a build up in a joint fitting. If youre not pulling out a clog and instead pushing it down the line you might need a longer snake.
The P trap doesnt need to recess into the cabinet, and youre missing an escussion ring. 🤔
