Where should I draw power for the COP's on my 95 4.6. now I'm getting it from the
fuse block. The problem is the COP's are not powered when the starter is cranking. Works fine in the summer not so good for michigan winter morning
Aren't the stock coil packs are wired so they are hot in start and run? Why not use that power source. Should be one of the relays in the box or just tap the wire from the coil harness.
I must of misread that thread. I thought 95 had an issue with taking the power from there.
I'll have to reread it.
thanks
