I believe it is for the variable assist power steering. You should be able to just remove it and buy something at home depot with the right threads to plug it with.
My EVO was a valve that threaded into the pump, then the line into the valve. If that's how it is, then you should be able to remove the valve and replace the line with a non-variable pressure line.
